I'm doing a complete body swap, including inner fenders and core support. While the body is off, will this provide enough access to the frame to do a good cleaning and get a coat of primer and paint on without pulling the engine, transmission, driveline etc?
I'm afraid if I pull the engine etc, it will become a bigger job than I'm ready for and take me forever to get back together, . Thanks for any advice
Repaint the frame- how much do I have to take off?
Re: Repaint the frame- how much do I have to take off?
I have torn my 70 F250 4x4 down to the frame and cleaned and painted it like you are working on as well. It does take time, and may be longer than you want, but if you are going that far into rebuilding your truck, why not do pull the engine as well and do a complete job? With the body removed, yanking the engine is a relatively simple process.
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1970 F250 4x4
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
as long as the engine is out, might as well rebuild it.
as long as the transmission is out, might as well rebuild it.
as long as the transfer case is out....
see where im going?
see where im going?
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
1976 Highboy
VW Sandrails
Honda ATC's
- Canonman67
As long as you can exercise restraint the time to pull everything is when the body is off, it will never be any easier. Go ahead and finish stripping the frame, pressure wash everything and paint it. The job will be easier and you will end up with better results.Bill Ramsey wrote:as long as the engine is out, might as well rebuild it.
see where im going?
Yes you will be able to it just depends on how time and patience you have cleaning and working around all that stuff. If you're just trying to make it look a bit cleaner but not really perfect then go for it
- Ranchero50
I wouldn't get insane with the cleaning and painting of the frame. Scuff the loose rust and use kerosene to dissolve the oily stuff, them hit it with some Rustoleum industrial black.
I wire wheeled my whole frame which took forever and sucked. I then put two coats of rust bullet over the whole thing and two coats of rustoleum gloss black over that. Turned out great. That rust bullet is tough stuff
Kyle
Kyle
- HIO Silver
.. enough to reach every nook and cranny. And there are lots of them.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
