Pressure for 235/85R16 E
- HOWDY69
For those of you with 235/85R16 load range E what tire pressure do you use in your F250’s when they are not loaded.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
- flyboy2610
fordman wrote:i can't seem to get the last project out of my bed before i have to put the next one in.
re: Pressure for 235/85R16 E
I usually run 35-40 psi unloaded. BTW running high pressures while unloaded not only makes the ride harsher but reduces the amount of traction available.
I use those on my 68. I usually run them at
about 55 pounds or so. Thats probably a good
"average" pressure for those. What I do is watch the
tire wear. If you start wearing a bit more in the middle
of the tread, vs the edges, you might have a bit too
much. But it will take a period of time to see that.
I'd prefer to run more pressure than less. Get better
MPG, less drag. More bumpy though... :/
MK
MK
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
