67 f100 project. Need some advice please.
A place for new members to introduce themselves
Wingnut310
Post by Wingnut310 »
Hey folks.
My name is JR, I've been a fan of this forum for a while now and learned a lot from reading some of the posts so first of all I want to say thanks!
This is what I've got its a 1967 f100 that I've started restoring as of now I've got the CV front mocked up I've got the explorer rear mocked up. I've got a fuel injected 302 and aod trans thats going in. Now I know there are quite a few people out there that are running this set up so I just have a few questions.
1. Ride height I've read that the cv front will lower the front 5 inches is that a fair estimate?
What about the rear? I am going to run the axle on top of the springs will that get the truck low enough in the rear to be close to level? I've got 5 inches between the top of the axle and the bottom of the frame should I c notch it?
2. Wheel size, I've picked out some 20x8.5 for the front and 20x10 with 4 inches of back spacing in the rear, I seen those wheel sizes on JG f100 build thread. Will there be any clearance issues?
I'm sure I'll have a ton more questions as I get further with the build
Thanks for ya'lls help!
JR.
HIO Silver
Re: 67 f100 project. Need some advice please.
Post by HIO Silver »
Howdy JR.
As far as the axle flip, mine netted 5.25 inches of drop.
Without notching, it'll have about two inches from the axle tube to the frame. You can either leave it be with a very stubby bump stop or C-notch it. I would do a C-notch because there will be that one pot hole, that one railroad crossing, or one time you'll actually need to haul a heavy load.
Dunno about the distance of a CV drop but that sounds about right.
Btw, calling it a 'restoration' is a misnomer. That means going back to OEM parts and configuration. What you're doing is a "build".
Good luck with it!
fireguywtc
Post by fireguywtc »
:wel: from Alabama! :fr:
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
lennyp
Post by lennyp »
:wel: from Massachusetts.
Mancar1
Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Post by Mancar1 »
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Madman
Post by Madman »
:wel: Colorado!
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1970 F250 4x4
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
