Hi folks,
i need a rear bumper for my 68 F100. Would a rear bumper from the 78 bronco fit? Is the width the same?
thanks Dirk
Rear Bumper
- hot-rod
- HIO Silver
Re: Rear Bumper
The bumper width is the same but the bumper bracket mounting holes are in the wrong location due to the wider frame width of the Bronco. Therefore, the brackets will end up "short" of reaching the frame on each side.
- hot-rod
Re: Rear Bumper
Thanks a lot for your answer. I think the bracket is not realy a problem. I was unsure because of the width of the bumper.
best regards
Dirk
best regards
Dirk
