swapping out rear ends
hillcountryflt
Post by hillcountryflt »
OK, I just recently cleaned up, painted, replaced axle bearings, etc on the rear end in my 71 f100 (240-cid, 3 spd light duty). I have recently acquired a much better in shape 69 f100 with the same configuration (except long bed and I believe the gearing is different 3.50 to 3.72 - I think).
Would there be any reason I could not swap out? I am going to be using the 69 as a daily driver and the 71 is going into project status, so I could swap out the rear end and then clean up the old one a little more leisurely.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
ToughOldFord
Re: swapping out rear ends
Post by ToughOldFord »
Same thing, no problem.
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
ultraranger
Post by ultraranger »
The ratio would be 3.70:1, instead of 3.72:1. Besides the 3.70s having more pull than the 3.50s, it will also make your speedometer read faster than you are actually going.
Steve
1969 SWB F100 Ranger. 240-6, C-4, 9" N-case 31-spline Traction-Lok w/3.50 gears.
1968 Mustang. My high school car. Owned since 1982.
2003 Azure Blue Mustang Mach1.
