Rear end q
1968 royal ranger
Rear end q
Post by 1968 royal ranger »
1968 ford 1/2ton rear end axles pulled, which way does the gasket ( not the seal) face , the ridged side..?....
Thanks. Mike :fr: :yt:
HAD A CHEVY,CHASED THE RUST ,CAME TO MY SENSES,BOUGHT MY FORD
BobbyFord
Re: Rear end q
Post by BobbyFord »
I'm not understanding the question. The gasket between the pumpkin and the housing?
ultraranger
Re: Rear end q
Post by ultraranger »
I gather that you are talking about the axle housing end flange gasket. Acutally, there should be two per side. One between the end of the axle tube and the back of the drum backing plate and one between the outboard face of the backing plate and the stamped steel bearing retainer (the stamped steel component with 4 bolt holes that holds the axle in housing).
You mentioned the gasket has a ridge. I'm guessing you are referencing a ridge around the large center hole in the gasket that fits over the axle bearing (?). Is the gasket made out of paper or is it made out of a very thin piece of steel?
Steve
1969 SWB F100 Ranger. 240-6, C-4, 9" N-case 31-spline Traction-Lok w/3.50 gears.
1968 Mustang. My high school car. Owned since 1982.
2003 Azure Blue Mustang Mach1.
1968 royal ranger
Re: Rear end q
Your right , 2per side, yes the lip around the 3in circle on gasket ,toward underside of truck or outward,all 4gaskets all metal thanks mike :fr: :yt:
ultraranger
Re: Rear end q
The ridge of the innermost gasket should face inward (toward the axle housing).
Steve
1968 royal ranger
Re: Rear end q
Thankyou :fr:
