Cargo light leaks
F100 Dad
Cargo light leaks
Post by F100 Dad »
I'm considering adding a cargo light to a 1970 bumpside. Do these tend to be source of cabin leaks? Even with new gaskets?
A Ford engineer I know says even today this is an issue for the cargo/CHMSL lights.
- 1970 Sport Custom long bed, 360 C6 2WD -
Re: Cargo light leaks
not that i have ever seen. maybe into the light itself. but never seen them leak into the cab. ive removed a few of them and never saw any rust or streaks in there.
Mancar1
Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Post by Mancar1 »
I have had these old Ford trucks for many years and never had a problem with that.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
jamesingarage
Post by jamesingarage »
I was thinking of adding one my self since i pulled every thing from a parts truck, i will also for sure be adding a set of LED bed lights that go under the bed rails out of sight..
Might be a option for you..
F100 Dad
Post by F100 Dad »
jamesingarage wrote:I was thinking of adding one my self since i pulled every thing from a parts truck, i will also for sure be adding a set of LED bed lights that go under the bed rails out of sight..
I'm actually thinking of putting red LEDs in one and converting it to a Center Mounted Stop Lamp (CHMSL) either in combination with some white LEDs for bed light or going with lighting under the rails like you are.
jamesingarage
I like the idea of the CHMSL, I belive my plans have changed ..
