Cab to far gone?
damn_fool
Cab to far gone?
Post by damn_fool »
I have a 71 longbed F100 and I'm not really sure if the cab is worth the work to fix it. The driver side floorpan you can see through(I could probably kick my feet through it with ease) the cab corners are gone, the cab mounts are toast, the support that runs along the middle of the cab on one side is non existent. Part of me is very intrigued at the thought of piecing all of this back together. I have never done any body work at all though or really any mechanicing period. Is this way to much to even attempt?
Jeremy
71 F100 that I haven't got to drive once yet. In pieces in the driveway =(
sargentrs
Re: Cab to far gone?
Post by sargentrs »
The only difficult part is that some welding will have to be done, it's unavoidable. Almost all of the sheet metal you're talking about is available aftermarket, except the inside cab corner pieces and maybe the under cab support and those can be pieced together or scavenged. There are a number of threads here that will show you what and how to do it. Virtually everybody has replaced their floor pans and cab corners and many have replaced their cab mounts.
72BahamaBlue
Post by 72BahamaBlue »
You might also check the cowl for leaks or rust through, and around the windsheild wiper pivots. Wouldn't hurt to pour some water into the cowl grille, test to see if any water gets inside the cab. Pretty difficult areas to repair, and you definitely don't want any water leaking into the cab!
The drip rail/gutter above the windsheild is another place to check for rust, and the vertical gutter at the rear of the door jamb, it's spot welded to the cab, I see a lot of trucks with rust through there too. Poke the areas with an awl or screwdriver, see if it easily goes through.
Sheet metal work on the cab can be pretty tricky and time consuming. Got any pics?
damn_fool
Post by damn_fool »
I don't have any pics yet. I need to read all the sticky's on how to re-size images and I'll try an get some shots of all the things that I can see wrong. Maybe an opinion or two from some of you guys more familiar with what to look for will see something too. A guy I work with is just trying to convince me into buying a completely different truck. This one was my dad's when I was little and he sold it about 3yrs ago and I happened to find it on craigslist and get it back in the family so I'm kinda attached to it.
Jeremy
72 f100
Post by 72 f100 »
This is the area they are talking about on the cowl and firewall area.
tac
Post by tac »
This part was fine on mine and the pivots to the left and right had rusted out. I took the cowl off to get to them, which I needed to remove torque boxes also to get it off. Lots of spot welds.
72 f100
Post by 72 f100 »
That's a lot of spot welds.
Whateverman
Post by Whateverman »
Save yourself a ton of work/time/ blah blah blah and find a better cab.
And: right on for finding your dads old truck, thats cool.
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
damn_fool
Post by damn_fool »
Driver Side Floor
Passenger Side Cab Mount
Driver Side Cab Mount
Driver Side Floorpan Under
Passenger Side Floorpan and Cab Support
Closer On Cab Support(if thats the name of that?)
Jeremy
sargentrs
Post by sargentrs »
I've seen worse. Check out Jerry's http://www.fordification.com/forum/view ... a&start=45 middle of page 4, and Tyler's http://www.fordification.com/forum/view ... &sk=t&sd=a bottom of page 1, and Patrick's http://www.fordification.com/forum/view ... &start=105 on page 8. All had similar issues like you, and me, and they're coming out beautifully (way to go guys!).
damn_fool
Post by damn_fool »
well I bought a welder so I guess I'm about to dive in head first
Jeremy
sargentrs
Post by sargentrs »
That's the spirit! Nothing like living on the edge. :wink: I recommend getting your cab mounts and floor pans from Dennis Carpenter. A little higher but much better quality.
damn_fool
Post by damn_fool »
Is there a specific name for what I'm calling a cab support under that passenger side? Don't know if anybody sells that particular part but it's probably going to be easier to find if I know what it's called :D
Jeremy
sargentrs
Post by sargentrs »
It's called the cab floor support brace. http://www.npdlink.com/store/products/c ... 50849.html or http://www.autobodyspecialt.com/cgi-bin ... ey=CMB-120 Tyler has a pic in his build thread, http://www.fordification.com/forum/view ... a&start=15 about 2/3 of the way down on page 2 (Thanks, Tyler!).
damn_fool
Post by damn_fool »
well I was browsing through the local craigslist and stumbled upon this http://tulsa.craigslist.org/pts/4253800182.html . Would this be worth looking at? Kind of hard to tell what kind of shape its really in from the pics/
Jeremy
