My predicament, need advice.
Craigerf100
Post by Craigerf100 »
Appoligies in advance for my rambling:
Okay so I need some advice. When all said and done i will be sandings, priming and painting my front clip of my truck. So 2 fenders a hood a grille and possibly a bumper, not to mention the valances. And they will be painting black. Like my truck is right now (I might change my mind of the grilles color).
My predicament is that, later on I will be doing all of the Above to the doors and bed. But not for sometime, as this is a budget build (Some minor rust issues).
So with the Front clip, part of me wants to sand prime and then stop until I can paint the whole truck. Then a part of me wants to try and paint the front clip black, color sand then buff. But If the 2 blacks don't match it will bug me. Since I don't know what type of black paint is on it now. And down the road I will be doing the same to the rest if the truck. One section at a time.
So to me logic dictates I leave it un painted.
If you all agree, then what can I spay over the primer to seal it till later? (As I will be driving it quite a bit) That would be easily sand-able for when I finaly get to paint the whole truck?
1964 F-100 Custom Cab Short Bed
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
1950 F-1 Original 239ci Flat Head V8 SOLD
1995 f-150 4x4 Swb 4.9L 5-speed FORSALE
My Build: :fr: http://www.fordification.com/forum/view ... &sk=t&sd=a
chad67
Re: My predicament, need advice.
Post by chad67 »
Black is always the same unless there has been fading. The level of gloss will most likely be the most noticeable. But...it won't be any worse than the mismatch between primer and paint. Just my 2 cents.
1967 F100 SWB
1991 Thunderbird 5.0 with fully ported gt40 heads, cobra intake (also ported) and a trickflow stage 2 cam, manual steering, and custom 3" exhaust
Craigerf100
Well i found this primer clear coat I found at autozone. Dupli color makes it. I just don't know if its easily sandable. Has anyone used it?
Craigerf100
chad67 wrote:Black is always the same unless there has been fading. The level of gloss will most likely be the most noticeable. But...it won't be any worse than the mismatch between primer and paint. Just my 2 cents.
Yeah I agree. But knowing me I would color sand and buff the heck out of it... Just to do again and again to the rest of the truck as i go. Then to do it all again when I'm ready to paint the whole truck. Too much work.
Ironically I don't mind the prime look. I guess because when I see classics with pieces of it in primer; it shows a work in progress.
Craigerf100
This is the gun I have, I've used it for small parts that I don't need to color sand and buff.
http://www.harborfreight.com/20-oz-high ... 47016.html
Anyone know how this will spray a my this paint?
http://www.amazon.com/Dupli-Color-BSP20 ... B0029818Q6
Or
http://m.homedepot.com/p/Rust-Oleum-1-Q ... =298346236
I'm thinking about getting this one.
http://www.harborfreight.com/profession ... 94572.html
chad67
Post by chad67 »
That's the same gun I use ($9.99 with the coupon from Hot Rod Magazine), and it has worked very well for everything I have sprayed. When doing larger jobs-mix a larger batch than the cup will hold so you can fill it quicker. I try to mix enough for 1 coat, then mix the 2nd......
1967 F100 SWB
Craigerf100
chad67 wrote:That's the same gun I use ($9.99 with the coupon from Hot Rod Magazine), and it has worked very well for everything I have sprayed. When doing larger jobs-mix a larger batch than the cup will hold so you can fill it quicker. I try to mix enough for 1 coat, then mix the 2nd......
The first link posted, that's the gun u use? Cool good to hear. Than you :)
70shortwide
Post by 70shortwide »
maybe just paint the clip and not bother to color sand it, then when you do the rest of the truck you can throw 1 more coat on the clip so it blends...
Craigerf100
70shortwide wrote:maybe just paint the clip and not bother to color sand it, then when you do the rest of the truck you can throw 1 more coat on the clip so it blends...
Hmm good thinking 70 shortwude :thup: I might just do that. Paint one coat now, then the 2nd and 3rd will be when I'm finally done.
chad67
Post by chad67 »
That's correct, the first link. Another option I've considered to make the gun more convenient is...check to see if a larger replacement paint cup will fit the smaller gun.
1967 F100 SWB
