I have a 68 F100 and found a front clip off a 67 F100 - it appears on the front end of the fenders, the edge where the bolt holes are in the area below where the headlights would be (to help visualize...), the 67 is a different shape.... looks like a "V" notch and it looks like it was built that way. Did not look damaged or that it had been hit???? Actually looks like it was pressed that way. The fender off the 68 in the same spot is straight as can be.
Anybody been doing this longer than me that can help explain this one? I will take pictures and attach when I get home from work tonight. But, thought someone might know off the top of the 'ol noggin!!.
Ford Fender quiz for the gurus out there!!
- doughboy68
- Mancar1
Re: Ford Fender quiz for the gurus out there!!
I think that notch was for the generator applicatin
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- chad67
I went out and looked at my '67 and it doesn't have the notch. Do both your fenders have the notch?
1967 F100 SWB
1991 Thunderbird 5.0 with fully ported gt40 heads, cobra intake (also ported) and a trickflow stage 2 cam, manual steering, and custom 3" exhaust
By the looks of your pictures , I think the bottom got pushed up and that pushed the edge out.
Try pulling down on the fender and pushing or hammering the point back in.
its down low where the apron or stoneguard bolts on looks like someone mangled it or it got smacked somehow..five minutes with a hammer and dolly and > voila!< good as new
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
- doughboy68
I think Mancar is the winner. I went and checked the other fender... Both sides (my other fender was with the truck at a buddy's, in the bed) have identical notches so I think the generator thought works... neither side is wrecked, the fenders are square with the world and came off a solid, straight front end clip. Thanks for all the input.... if someone else knows for sure, I am still open for a 100% explanation....Mancar1 wrote:I think that notch was for the generator applicatin
