Bleeding Front Hubs
Bleeding Front Hubs
What kind of wrench do you use to bleed the front hubs? A combo wrench goes onto the bleeder valves at an angle so the wrench is only half on the valve. I was able to get the driver's side valve loose but not the passenger's. Is there a better tool do do this with?
re: Bleeding Front Hubs
Try an offset wrench
Lord, give me the restraint not to cuss over busted knuckles.
- spartman
