In cab gas tank plates
69Ford
Post by 69Ford »
Looking for the plates that are mounted by the cab mount bolts. They have a lip to hold the gas tank in place They are located at the bottom of the gas tank bolted to the floor.
will take a picture tonight. If anyone knows of or has a set for sale let me know. Also is there anybody making these aftermarket. Thanks 69F100 Opps added wrong picture have included
right one Thanks.
sargentrs
Re: In cab gas tank plates
Post by sargentrs »
I think I have a set in my pile o' parts in the basement but it'll be a couple days before I can scrounge around. If somebody else comes through for you before I get to it, go ahead and take 'em. I understand "urgency". :wink:
69Ford
Post by 69Ford »
Thanks No urgency using the tank under the truck for know. Just a little history the truck had a fifth wheel camper on it was jackknifed into the cab at highway speed. (To small of truck to big of trailer) The cab was fixed by local bodyman in 1994 And now I'm trying to fix it correctly and one of the parts above was pretty bent up because the cab was pulled off the frame. So much for a nearly perfect Cab.
1969 Ford F100 Styleside standard cab 360 C6
sargentrs
Post by sargentrs »
Sorry, must have tossed 'em. I found the box that had the old cab mount bushings and mounting hardware in it (got from a member on here) but the plates weren't in the box. I had blasted and painted the mounting hardware to reuse but since I'm not putting my tank back in the cab, I must have thrown them away. Sorry, again!
69Ford
Post by 69Ford »
Thanks again for looking. If any one else knows where I can get a set let me know.
