grill paint removal
676870F100
grill paint removal
Post by 676870F100 »
I have a 67 grill but it was painted black - how do I safely remove the paint without hurting the metal
guhfluh
Re: grill paint removal
Post by guhfluh »
Aircraft stripper won't hurt the metal. It's a nasty process though.
A softer wire wheel should work too, and its what I plan on. Media blasting would be nice, but spendy.
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
69Ford
Post by 69Ford »
Was the grill factory painted grill or an aluminum grill painted by someone.
1969 Ford F100 Styleside standard cab 360 C6
chicof100
Post by chicof100 »
69Ford wrote:Was the grill factory painted grill or an aluminum grill painted by someone.
No aluminum grille was painted from factory other than the vertical bars top and bottom.
As was said before use aircraft stripper. Use outdoors, wear gloves and a mask, read label real good.
1964 f100
292 yblock
1969 Ranger
Loving all ford vehicles
676870F100
aluminum grill painted by someone - where can I buy this stripper at?
guhfluh
Post by guhfluh »
Check to see if it eats aluminum first. I don't think it should since aicraft ARE aluminum. I didn't think you were talking about an aluminum grill, since they normally aren't painted.
Anyway, any hobby shop, auto parts store, Walmart, or hardware store should have some.
