Now that you have regs out, remove the springs(be careful they are under some good pressure).
Now drill out the three rivets that hold the crank assembly in place.
Remove the gear from reg and discard.
now you'll need to mark the reg to be cut.
You see how the reg kinda dips down then back up where the threaded inserts are? You'll be cutting off right where the dip stops coming back out.
Now you'll need a die grinder or a cut off wheel, a hacksaw can be used but will be difficult to get a straight cut across. I used a 14" chop saw(very dangerous to use one of these as there is no way to clamp reg down, I had to hold by hand).
Once you get it cut it should look like this.
Now you'll need to get the power reg's and remove the motors, be sure to take the gear housing with the motor. Now I did mine a long time ago and didn't take pics as i worked on them! I did remove mine so I can show you what they should look like.
Ok the red arrows is where a cut is. So basically everything above the red arrows is what I cut off of the power reg.
Note that the motor on its original reg will be mounted at 90* and will have to be turned and mounted so it will be mounted above the reg going into your truck. Basically the motor will be straight up and down. Do this by removing the three screws(blue arrows), and rotating motor on the mounting plate. The holes may need oblonged so holes line up. Just be sure the shaft of gear housing is in the bushing when mounted.
Then welded it to the original reg, So it ends up looking like this.
When welding be sure to weld across the width and also down the side of the dip. should look like this.
Now that it's all welded together, you'll need to put the spring back onto the regulator, then install the motor and gear housing onto the regulator with the motor pointing straight up. Now apply 12volt's to the motor to make sure it operates smoothly. Being careful as the arm will move rather quickly. It don't really matter which wire is positive or neg as you just reverse the wires to reverse the motor.
Now if it operates smoothly then install motor and regulator into your door. I did it with the window all the way up. You will have to power the motor momentarily to make the holes line up to their original bolt holes(kind of a pain in the A$$).
Now that the new motor and regulator are installed, it's time to start the wiring.
You'll need 8 wires the same gauge as the wires in original harness, I tried to match the colors as best I could. Each wire will be approximately 6ft. in length or as wide is the cab, one will be about 10ft. long. The 7 shorter wires just go from one door to the other. The longer one will also go to a power source. solder the wires to the harness plugs you cut out of donor truck, making sure to color match each one to the other. On the truck I got mine from the blue wire was the power wire feed which will be the longer wire. I soldered it to the drivers side harness and ran it across to the pass side then out to the engine compartment. I hooked it to a 30amp breaker the to the battery side of the starter relay.
It's one of two wire's you'll need to hook to truck. One is power, the other is a ground, which hooks to one of the regulator mounting bolts inside drivers door. Once all the wires are soldered i wire loomed them together and secured them under the dash. I ran the harness plugs through the factory rubber plug to the area where the door hinges are.
Now drilling the door for the harness. I used a 3/4" drill bit and drilled the door about 2" from inside of door, and level with the big hole in cab.
I wire loomed the wires going from cab to door.
Now with all the wires ran and hooked up, you'll need to find a place for your switches. I mounted mine in the door just above the regulator, but in front of the window track.
I welded patch panels over the original window crank holes(was going to paint door panels but decided to just cover in vinyl).
It'll take some figuring to be sure you get the hole in the proper spot so as not to inter fear with reg's range of motion. I'll take some measurements off of mine and post later. I did cut the doors before i did the panel. That way I had a little leway for adjustments. This is how mine looks when completed.
Now give them a try! Hope you enjoy your power windows as much as I do
How do you like my home made arm rest? Made them out of pieces of red wood 4x4's. Then painted them to match my truck.
If anyone has any trouble or needs help pm me and i'll help you as much as i can.
