Hey fellas. Need a few parts for the highboy to get it back on the road.
I need the brake lines that go from the master cylinder to the proportioning valve on the frame. I am not sure if these need to be off another highboy?
I also need all the hardware for assembling a set of bumpside doors. As in the screws and little nuts and bolts for the locking mechanism, regulator, handles, vent window, allll that good stuff.
Also need 67-69 aluminum headlight doors in good shape.
F600 cluster
Axle shafts and brake calipers for a 78/79 f250 4x4 dana 44 too..
Brake lines off MC, door hardware, headlight doors, f600
- 1971ford
- Alstoyz
Re: Brake lines off MC, door hardware, headlight doors, f600
I should have the brake calipers, and the door hardware...
1970 F-100 SWB Tubbed
1971 F-350 4X4 (traded for 71 crewcab)
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-350 Crew-Cab 4X4 Dually
2001 F-350 Crew-Cab Short Bed 4X4 Dually
1972 F-100 SWB 4X4
- 1971ford
If the calipers are in good shape that'd be great.
I tore mine down, blasted them and ordered rebuild kits but after playing with them and asking around, you just can't rebuild these things. I've spent 4-5 hours attempting to get the seals seated and the tolerances are too tight.
I can get new calipers for $80 but if you've got some good used ones for cheaper to get me by and the highboy back on the road sooner i'm game!
Let me know what you'd want for the calipers and door hardware
-Ryan
- 1971ford
