Used Air Compressor...
- Nitekruizer
I've been wanting an air compressor for quite some time. I have the chance to go look at a used one advertised in the local classifieds. It's a 2 hp model with a 12 gallon tank, not "oil less". I am a hobbyist and would like to use it in my garage for everything from pumping up tires to powering a paint spray gun. I've never owned an air compressor before, so, I was wondering what kind of things I should be looking for? Thanks in advance
390 FE IN A "BUMP" / 383 WEDGE IN A 2 DOOR C-BODY / 351W IN A FULL-SIZE MERCURY / 194 CHEVY 6 IN A DUECE / 2.4 DOHC CHRYSLER IN A PLASTIC BUBBLE (Driver)
- sargentrs
Re: Used Air Compressor...
If it runs and holds air the only other thing is the regulator and pressure gauge. If you're going to be spraying paint you should get a drier/filter to go between the compressor and your gun.
- Mancar1
Good advice ![Yeah that :yt:](./images/smilies/icon_yeahthat.gif)
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- stephen44
rather than HP - you need to look at the CFM rating - this is the amount of air it can produce - most hvlp spray guns need between 8 an 15 at 30 psi - power tools need 10+ at 90psi
also be aware - compressor manufacturers are very optimistic in their ratings and i usually take about 70% of their rating as what I will likely get
thanks
Stephen
Stephen
- Nitekruizer
Thanks guys. Going to look this evening so I'll check all of those.
