Dana 44 or Dana 60 1/2 ton rear axle wanted
- Art
Looking for the axles and housing (or parts) from a Ford 1/2 ton (5 lug) Dana 44 or Dana 60 rear axle. Any gear ratio or carrier type. Prefer 1967-1972 but will consider 73-79 trucks as well. Thanks.
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
Like vintage drag racing? http://www.meltdowndrags.com
- Dirty Offio
Re: Dana 44 or Dana 60 1/2 ton rear axle wanted
Um, I ain't gonna swear they didn't, but I am pretty sure that the trucks came with either a Dana 44 or a 9 inch Ford rearend...not a Dana 60. Lightest rig I know of that came with a 60 in Ford is a 3/4 ton. So, while you could put a 60 in the rear of your 1/2 ton easy enough, the lug pattern will be 8 on 6.5", not 5 on 5 1/4"
Honestly, I would stay with the 9 inch in a half ton. They are hell for strong, and easy to get parts for.
just my worth.
Offio
just my worth.
Offio
When in doubt, hit the gas. It may not be the right answer, but at least it ends the suspense!!
The only substitute for Cubic Inches, is Cubic Money!
1967 F-100 swb "Varmit"
1968 F-250 4dr lwb "Beast"
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
- Art
The bolt pattern for the 1/2 ton trucks in this era is actually 5 on 5.5"
and yes some F100s DID roll down the assembly line with a Dana 44 or Dana 60 (technically a Dana 60-3) under the back:
http://www.fordification.com/tech/dana-rear-01.htm
- Art
back to the top as the search continues for a 67-72 1/2 ton Dana 44 or Dana 60 axle...
If your still interested ,I have the dana 44 complete unit from a 65 f100. 3.54 gears with posi (power lock). I will be traveling back to Mi in June ,for $500 I will meet you in the Chi town area for p/u. To break it down thats $300 for the rear and $200 for del. Regards,yourpartsdude
- Dirty Offio
Art wrote:The bolt pattern for the 1/2 ton trucks in this era is actually 5 on 5.5"
Oops, I actually knew that was the spacing...that will learn me not to answer posts when I am fragged out from work! My bad.
Um, I DID say, don't quote me on this first off, and second off I DID mention the Dana 44.
Learn something new every day, I have never seen an F-100 with a 60 in the rear...so, cool!
Hope you find what you need.
Cheers!
Offio
ps, I would still run a 9 inch. Just personal pref. I have more trust in the 9" is all.
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
