How do I restore a steering wheel?
jjsuave
Post by jjsuave »
I get a call the other day from the guy that sold me my 67. Says he found the original steering wheel for it, so I go pick it up. It's in good conditon except for some of the finish is rubbed off and some deep cracks and gaps.
How do I restore this steering wheel? I'm thinking of using some kind of epoxy or plastic to fill in the cracks, sand it down, and paint it.
I would appreciate any ideas on this…
bigwhiteford
Post by bigwhiteford »
I have heard JB weld does wonders.
Proper capitalization is the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse.
QC
Post by QC »
One of the parts places has a sterring wheel restoration kit, possibly NPD or LMC. I can't remember. I'll see if I can find it.
69 F-100 Ranger 302
dcbullet
Post by dcbullet »
Por-15 has a resto kit but it's expensive.
Mine doesn't have any cracks in it but when it's hot my hands turn black when I hold it. :-/
bluef250
re: How do I restore a steering wheel?
Post by bluef250 »
Do an Internet search for Steering Wheel Repair Restoration. Lots of information and how to's about the subject. To many to post here.
Stroked
Post by Stroked »
I've seen a couple kits to restore steering wheels, but you have to paint it and I wonder if the paint would eventually rub off.
1963 Galaxie 2-door sedan 260/3-speed
1971 F250 2wd 360/4-speed
1986 Chevy K10 305/auto
Many, many parts vehicles.......
bigwhiteford
dcbullet wrote:....when it's hot my hands turn black when I hold it. :-/
HAHAHA ! I thought I was the only one who had this problem! I guess it's a mark of "oldforditus" :D
Joe Kriston
Post by Joe Kriston »
I know I've read an auto restoration book somewhere(either for a Mustang or a T-bird) that gave step-by-step illustrated instructions on restoring a steering wheel...I remember it saying you take a Dremel tool or something and cut a "v" groove in all the places you use filler so it has something to adhere to and stays intact....I think it also had the restorer using a special clearcoat over the painted steering wheel...I don't know what they do with those old transluscent DeSoto steering wheels....
This is the point...I'm....talking about everybody! I'm talking about form! I'm talking about content! I'm talking about interrelationships! I'm talking about God, the devil, hell, heaven!!!! Do you understand???? Finally!!!!
jzjames
Post by jzjames »
I doesnt need to be complicated and I dont think you need expensive resto kits. I did it this way.
-washed steering wheel in warm soapy water, when dry,
-J-B weld the cracks, stuff it in there with toothpicks,
-shape your fills and sand with fine grit paper,
-paint, no primer, I used epoxy for its durability. That is probably what the kits use for paint as well. You can get the epoxy in cans called appliance paint in black, white, and almond. The 'almond is very close to wimbledon white. :clap:
bigwhiteford
check out this little linky I found ...
http://www.thebugshop.org/bsfqstrg.htm
it looked good. he used por 15
jjsuave
Post by jjsuave »
Cool. This is all good info. Thanks everyone. I think I'll try cleaning out the cracks real good, then using some of that POR15 stuff, sand it down, and painting it. It will look much better I'm sure.. :drive:
With no power steering so that little steering wheel that's on there now.. makes it hard to navigate around a parking lot. Maybe the previous owner put it on in case he had to drive with handcuffs on... :wink:
1967 F-100
390 C6
towens
Post by towens »
I have heard that POR-15 is good, but it sure is expensive.
TRAVIS OWENS
"Never argue with an idiot; they will only drag you down to their level" -Anonymous
1972 F-250 CAMPER SPEC: SPORT CUSTOM 360 2WD; C6
1995 Ford Mustang V6; C4
1981 Honda 70c Passport Cub
1982 Honda Trail 110
jz how long ago was it that you redone your wheel? how much have you used your wheel since you refinished it. and how has it held up so far?
jzjames
Post by jzjames »
That wheel held up excellent using JB Weld to fill a minor crack and epoxy paint. I recently traded it out for a Grant wheel of a smaller diameter and foam grip. I used the refinished stock wheel on my truck for 2 or 3 years.
