Dana 44 swap
Dana 44 swap
My 67 F250 4x4 will be getting the axle treatment very soon. I have read the forums and tech pages for power steering set up, and have purchased a 74 D44 with discs and calipers. I have measured the pads and they look to be the same. I bought the entire power steering package from a 76 F250 2wd. I am confident I can do the mods.
Unfortunately the ratio for the front is 3.54 and the rear is 4.56. I think I want the rear to match the front, and my confidence has turned into a quivering mass of bovine excrement. Regearing a Dana 60 requires proper setup and special tooling(I think). Gear sets and rebuild kits and shop fee's will destroy my budget. I am not building a trailer queen, this is my truck.
My question is this........should I buy another D60 or regear? If I regear, do I have to totally rebuild it? Can I use used gears?
Thanx
Thanx
- boots
re: Dana 44 swap
im not sure if you have to re-gear it, I really dont think you do.....but I would never buy used gears.
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- heep70
If you re-gear it you will need to purchase another carrier to handle the 3:54 R&P. As far as a total rebuild, "Yes". Just the center though.
It would cost you allot more to re-gear, but you might spend some time finding a good 3:54 9"rearend.
Oh by the way
to the site. Please fell free to hit the :welcome mat" and intro yourself and your Ford. We like pics if you have any.
Oh by the way
![Welcome :wel:](./images/smilies/icon_welcome.gif)
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- heep70
Greg
- boots
Re: re: Dana 44 swap
sorry typo, I meant I was not sure if you would have to re-build it.boots wrote:im not sure if you have to re-gear it, I really dont think you do.....but I would never buy used gears.
anyways yea look into that 9" rear end.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
Alrighty then. I will look for a 3.54 rear end and swap it. Mckenna is a bit far to drive for a rear end. I will get a Dana 60 due to the fact I just replaced every brake componant, and I can reuse most of it. I will read the forums again and find what years have the same width spring perches. I don't have a cutting torch, just a welder. I need to keep this truck under budget. I AM going to get this truck done as a budget rod. I will be painting in Jan. I have to get the frame work and suspension completed. I will post some pics as soon as I can figure out how to post pics. Thanx guys.
67 F250 4x4
- heep70
You did say a F250,
sorry. It might be a bite harder to find a D60 w/ 3:54.
Greg
used gears are ok as long as someone has marked the backlash, pinon depth and runout on them but that never happensboots wrote:im not sure if you have to re-gear it, I really dont think you do.....but I would never buy used gears.
- boots
oldschoolrods wrote:used gears are ok as long as someone has marked the backlash, pinon depth and runout on them but that never happensboots wrote:im not sure if you have to re-gear it, I really dont think you do.....but I would never buy used gears.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 72hiboy4x4
hey aesop, I may have what you need here. '71 dana 60 with full true-trac. PM me if you are interested.
never mind, I just wandered out to look and it has a 3:73 ratio.![Embarassed :oops:](./images/smilies/icon_redface.gif)
I thought the Dana 60 was a option on the 97 F350(?). However, the Sterling axles made for Ford will work just fine if the width is nearly the same. As far as I can tell face to face will be 1.4" wider on a Sterling. The axle should be a 6.5" stud pattern. 170mm stud pattern should be on the 99 and above(?) and does the ujoint input sit in the same place as my 67 yoke? Thanx
67 F250 4x4
