dual brake warning switch connector
- 69f-100
Does anyone have a dual brake warning switch connector, that would work for a 69 f100 2wd? It is the two prong connector that is on the wiring harness that goes down to the dual brake warning switch. I am desperately in need of one of those to get my wiring finished.
- Alstoyz
Re: dual brake warning switch connector
I'm pretty sure I've got one. Are you needing the the plug that has the two pinkish purple wires that connect to the distribution block on the frame rail???
1970 F-100 SWB Tubbed
1971 F-350 4X4 (traded for 71 crewcab)
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-350 Crew-Cab 4X4 Dually
2001 F-350 Crew-Cab Short Bed 4X4 Dually
1972 F-100 SWB 4X4
- 69f-100
yes, that is the one.Alstoyz wrote:I'm pretty sure I've got one. Are you needing the the plug that has the two pinkish purple wires that connect to the distribution block on the frame rail???
- Alstoyz
Pm sent.
1972 F-100 SWB 4X4
1972 F-100 SWB 4X4
