Center support bearing
ajsmolik
Post by ajsmolik »
1971 f100 360 2wd (2-piece drive shaft)
I'd like to replace the U-joints one of these weekends, and thought I'd better replace the center support bearing also.
Any hints on how to do this? Does it just drop down and slide off?
no it has to be pressed off of the shaft and a new one pressed on.
steveheer
re: Center support bearing
Post by steveheer »
Most auto parts stores have the press to r&r the carrier bearings. Good idea to at least check and if at all questionable replace. They can leave you stranded!! :cry:
Steve
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
dotcentral
Post by dotcentral »
I got mine pressed off and the new one pressed on at a driveline shop. Think it was about $25.
