lifting a 2wd
air shocke maybe or a couple of more leafs in the rear springs. a larger block between the differntial and the springs. to lift the front you could put heavier coil springs under it. just some quick ideas.
Heavenlyfire
Post by Heavenlyfire »
I played around with turning the I beams upside down, didn't work. lol I think about the only real good way is to buy or make brackets to lower the I beam. Boots has been working on a set and it looks like it should work.
rjewkes
Post by rjewkes »
Before somebody flames you real bad Heavenly, This is raising it question i think you thought you had wolfpaks' question of lowering it in your head?
fuelly.com
spartman
Post by spartman »
No rjwkes, heavenly actually tried to raise his truck by inverting the I-beams.
heep70
Post by heep70 »
Boots would be the dude to talk to.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
boots
re: lifting a 2wd
Post by boots »
Well, You have to get some lift coils, or some coil spacers. I think lift coils are the way to go though. Check rancho or skyjacker for them. After you get thoes, You will find your camber will be off. You have to either get your i-beams bent, or make drop brackets for your i-beam (which I did). Next, you must drop your radius arms. I have a 4" lift and Im in the process of doing about a 3" drop of the arms, and im extending them 10.5 inches. If you lift 4" or more you will probably need a drop pitman arm also. For the back, you can go ahead and do lift blocks. I would not go over 4" inches for the blocks though. I have blocks, but soon im going to fab up drop brackets for the leaf's, or just get sky brackets. Any other questions just ask, hope this helps. :D
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
Heavenlyfire
re: lifting a 2wd
http://fordification.com/forum/viewtopic.php?t=3796
Give this link a look at and you can read about the whole thing lol. It was fun.
ivansgreat
re: lifting a 2wd
Post by ivansgreat »
Thanks to all of you. I have one more question. Who makes a good product for me to use to give my truck a lift? I've been looking but can't find something for a 2wd. All I find is Bronco and 4wd lifts.
Ivan
1968 F100 2wd
302
heep70
Post by heep70 »
Boots mentioned Skyjacker or Rancho. Look for F100 4x4 coils.
Greg
460 crew
Post by 460 crew »
Autofab.com has 2wd lifts. quality stuff
mrung0wa
re: lifting a 2wd
Post by mrung0wa »
YeaH, :yt::thup: :fr:
I must commend Brother boots he has really done his homework and I plan to utilize his drawings for the front of ol' Jethro.
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
ivansgreat
re: lifting a 2wd
Once again, thank you all. I really learned a lot about my options.
Ivan
1968 F100 2wd
302
boots
re: lifting a 2wd
Post by boots »
no problem! :D
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
boots
Re: re: lifting a 2wd
Post by boots »
mrung0wa wrote:YeaH, :yt::thup: :fr:
yea but now i gotta go do biology :o
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
