Are they the same as the F250 2WD or are they different. Does anyone sell a poly kit or am I going nuts looking?
TIA
Eric
F250 4x4 rear leaf spring bushing
- 71PA_Highboy
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Re: F250 4x4 rear leaf spring bushing
I would think they would be the same up to 77.5. But unfortunatelty I don't know. I'm sure you have checked Bronco graveyard? For what its worth I put the rubber ones back in mine. Figured if the lasted that long, should be good enough for me
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- 69FLATBED
Check NPD I was looking at them last night but I can't remember, it seems like they are different though.
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
- Manny
I asked the same thing awhile back i have been told they are the same that is why you don't see a different kit for 4by I was told the 2wd kits fits haven’t tried it though yet......71PA_Highboy wrote:Are they the same as the F250 2WD or are they different. Does anyone sell a poly kit or am I going nuts looking?
TIA
Eric
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- Manny
My other thread and what fordman told me......
http://www.fordification.com/forum/view ... =9&t=55516
- 71PA_Highboy
So I went to Mecca... took the leaf springs into Summit Racing.
NOTHING fits.
That said, IF you were to leave the Outer Liner in the spring eye, and machined the bushings to have a different inner steel spacer and cut the bushings down, you could use a 73-77 F250 4wd Kit.
If you just wanted to machine the outside and replace one of the inner steel spacers (on each side), you could use the energy suspension '3 bushing shackle' setup, but it does not have enough of the inner steel spacers of the right size to do the job....
Caveat... I removed the original outer steel bushing retainer.... if that were left in place, the 73-77 kit would be EASIER to machine to fit, but would NOT directly fit.
I will be calling Prothane Monday to see what they can do....
More later.
NOTHING fits.
More later.
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- Manny
Dang well that stinks for sure i wonder if There is any other kits that carry that same size. Hopefully prothane can tell you something about it when you call them. I sure hope so.
- 71PA_Highboy
Well,
Prothane, Energy suspension and Daystar only sell based on application, and if you call their tech line they have no way to look up bushings by dimension. How stupid can you be?
Anyway, here are the dimensions required for the bushings as far as I can tell... I will be having some made next week, so I will let you know how it works out.
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
