bracket studs
- boots
bracket studs
im taking my radius arm brackets off on my 67 f100. I already grinded down the end of the studs holding it in place to the frame and crossmember, and its still not budging at all. Im not looking forward to drilling each stud, nor would I think I would have to because I already grinded off the end, I tried punching it through also, didnt work.
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Sharkdance
re: bracket studs
I did mine with an air hammer.
I used the chisel bit to cut the heads off, and the straight punch bit to push them thru. A little heat might help them along too.
- boots
Re: re: bracket studs
ok, thanksSharkdance wrote:I did mine with an air hammer.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- flyboy2610
re: bracket studs
The rivets are swaged into the frame. A good sturdy punch and a 3 pound sledge hammer should take care of them.
- 72hiboy4x4
