i picked up a junkyard t-case today, but to my dissapointment turned out to be a NP207. i was wondering if it would work to convert my M-100 to a 4x4? or is it to light duty? is would be going behind a 240/3-spd so deffinatly not a powerhouse...haha
if it is good enough i would get an adapter made to make it divorced, and then SAS the front end with a dana 60.
t case question.
t case question.
1967 Mercury M-100
240 i6
3.03 trans
3300IB 9" 3.70 Gears
240 i6
3.03 trans
Re: t case question.
Not to rain on your parade but anything can be done. This is my opinion of what you have. I wouldn't run the 207. I personally don't have experience with them. I am pretty sure it is a less popular swap.I know it would be alot of work for you to put in that transfercase and then be disapointed in. There is alot of work invovled in converting a 2wd truck to 4x4. The way most people go (and I do agree with it) is to swap the body you have or like onto a 4x4 chassis from the 67-72 era. From what I here the 3 speed isn't know for its strength. I think you would be alot happier with the final result doing a frame swap. These are my opinions and not neseccarily fact. Either way you go, best of luck.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
the thing is that the truck is a mercury truck and i want to keep it as orignal as possible..haha exept for 4x4 of course
the trans will probably change to a 4 spd and the motor will probably change to a 300. but nothing more then that.
if the t case is good enough, i would make it divorced.
the the alternative is you guys tell me to grow a pair and go BUY a NP205, haha
1967 Mercury M-100
240 i6
3.03 trans
240 i6
3.03 trans
- harrysnyder
I wouldn't cut up your original Mercury truck. Just buy another truck, that's 4x4. By the time you buy springs, metal, u bolts, brake lines, steering, and a transfer case, you could find a 4x4 for that. I paid 1500 for my Highboy.
I build driveshafts.
www.carolinadriveline.com
71 F100, 302, C4, 8.8, crown vic swap
68 F250, 360, NP435, Dana 24, Dana 60's f&r
