Buying an ebay posi unit
Help I know my truck has a 9'' rear but don't know whether it is 31 or 28 spline how could I tell it's a 72 with a 390. Seen this great deal on a assembled unit ready to throw in just need some info
- roachrider
re: Buying an ebay posi unit
I believe all the 67-72 truck 9" rears are 28 spline. However, wait to decide on your purchase until someone else that has direct experience with those rear ends confirms it.
Thanks,
-Aaron Taylor aka...Mr. Winch
1967 F-250 HiBoy - 352ci, NP-435, Dana 24, Dana 44 & 60, 4.56's, Riding on BFG 35's
1982 KZ-1300 - 650 pounds, 120+ HP, 85 MPH Speedo
Thanks I am leaning on a ball park decision I also think it's 28 spline but heard in 1970 they started bring the 31's for those trucks....I guess I have no other choice then to wait till someone approves our hunch
Hmmm....as far as I know all '67-'72 trucks with 9" rearends had 28-spline axles. However, I'm not 100% sure when the 31-spline versions started showing up.
- heep70
I agree, 28 spline.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Alright 28 splines it is and if it doesn't fit my neighbor said he would by it for his ranchero thanks guys
I think the only way to know for sure is to pull an axle.
Some say you can tell by the size of the nuts holding the flange on but I don't think it's 100% either.
Mine has 3/4" nuts with small bearings and 28 splines.
It's a 71
clint
It's a 71
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
That's a good guide to go by but these trucks are 25-30 years old. Alot can happen to a truck in that time. Rear ends are changed, engines are swapped out. etcfordman wrote:the interchange book i was told said 28 spline for 67-72 and 31 spline for 73-79. he was reading the book while i was sitting there.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
