Hey guys. I'm new here, as well as to 67-72 pickups. I bought a pretty decent 71 swb 2wd and have begun a long process of upgrades. I swapped in a new column, gearbox, pump and lines from a 79 F150 to convert to power steering. The problem I have discovered is that the pitman arm is larger on the p/s gearbox. Does anyone know where I can find one? I can go buy a used gearbox that already has one, but would rather not because I already bought a reman box. Any suggestions are greatly appreciated.
Seth
71 F100 pitman arm
- heep70
![Hello :hi:](./images/smilies/icon_hello.gif)
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
re: 71 F100 pitman arm
Im in Michigan. Grand Rapids area
Sorry, I should have been more specific. The output shaft on the power steering box is larger then it is on the manual box. Length is not an issue.
Seth
Seth
- flyboy2610
He's correct.
The shaft on a MS box 1.125, the shaft on a PS box is 1.25.
