How much can you lift a highboy in the rear until you get to the point where the driveshaft needs to be lengthened?
Looking to add enough leaf springs to the rear packs to give about 2" of lift, i am hoping that the driveshaft does not extend too much to where if i flex the truck on the trail it will not try to pull the driveshaft apart. The front i lifted 3.5" and the driveshaft won't even bolt back into the yoke while being 100% extended, and at ride height (re-tubing it now).
Rear lift - driveshaft problems?
- 1971ford
- averagef250
Re: Rear lift - driveshaft problems?
A high pinion front axle will make that front driveshaft fit just fine.
You can get a good approximation of where your rear driveshaft situation is going to be by unbolting it at the rear end yoke and dropping that end down exactly two inches vertically.
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
