lowering the f250 crewcab!
- gregamorton
guys I was wondering if the king pins in my 71f250 are the same size as the f100 trucks. I have a new set of dream beams on a f100 that I have never finished and got to thinking about maybe using them on my crewcab. I am going to go out side and measure the rear leaf springs to see if they are the same width to use the rear lowering kit.
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
- gregamorton
Re: lowering the f250 crewcab!
It looks like the springs are 2.25" on both my crewcab and my f100. My crewcab also has the smooth ride rear shackle and it looks to be a little over 2.75" just like my f100 also so my whole kit should work as long as the king pins are the same size!
The rear lowering shackles and hangers will work on the rear, Im not sure about the kingpin size though...
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- gregamorton
I found a post that states there is two sizes for the f250 but it does not go into detail about which or how to know. I know that mine is a 71 and it has drum brakes on the front rather than disk like most I have seen.
