Swaping from FMX to C-6. I have a 1967 F-250 with 2 peice driveshaft. Got the donors front driveshaft from the bolt on yoke to the carrier bearing. Not really thinking that they would different diameters. I got it home and it is about 3 inches shorter wich fixes the length issue and it slides right on my old back half of the driveshaft. So they mate right up. The question I have is can I use the larger diameter front with the smaller diameter back half? I dont see this being an issue but if anyone has done this and recommends against it I would like any advice for or against this swap of the front driveshaft.
Thanks.
Driveshaft question
- 67F250CS
Driveshaft question
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
re: Driveshaft question
Hmmmm....I've haven't run into that before, but I don't see why there would be any problem with the two sections having different diameters, as long as they're the correct length and mate up just fine.
- lobuck76
- 67F250CS
I though it was ok, ITs a FORD afterall. I'll run it ans see what happens.
Thanks much.
Thanks much.
- wt4speed#2
With the shafts being 2 diff diamiters I might recommend taking them and having them match balanced to avoid vibration
Tony B
Tony B
- willowbilly3
Just make sure you have them timed or phased right when you slide the 2 together and you should be fine.
- 67F250CS
Thanks, I downloaded the thread that had pictures of the proper phasing. A few weeks ago I think it was. I appreciate the advice.
