part from the diagram at...
robertbruce
Post by robertbruce »
hello all,
does anyone know where i can get the parts from the following diagram
http://www.fordification.com/tech/image ... ront01.jpg
i am looking for the RHS steer knuckle
Daily Driver
4x4 Toyota Coaster build up with chevy/gm mtr/tranny and the tuff 67-72 F250 drive train...
The xcase is divorced, there are no adapter plates, it's fully engineered with blueplates and a very tight conversion...
Worksshop foreman for son's vehicles;
BJ73, diesel, PTO - the bus's mechanical recovery vehicle
NG Paj, sunroof - the bus's passenger recovery vehicle
Re: part from the diagram at...
the links page has lots of vendors on it. you could look there. for hard parts the parts wanted section is good to ask in. i know where one of those axles is sitting at.
robertbruce
Daily Driver
i will get some pictures of the one i can get to.
mybros71
Post by mybros71 »
I've worked on quite a few of these axles (all were LHS vehicles), and never come across the bracket you have in the photos with the knuckle. Is it possible Dana or the supplier who put that axle under the vehicle added the bracket to adapt the typically LHS axle to RHS? I'm assuming the steering arm bolts to the top of that bracket.
In any case, that knuckle looks identical to every other one I've seen on a closed knuckle Dana. If that's the case, I think a used knuckle should be easy to locate.
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
robertbruce
Heya' MyBros.
the bracket is to increase strength to allow power steering
im stiil trying to source a knuckle for it - any suggestions??
Daily Driver
robertbruce
many thanks FORDMAN, i look forward to the pics...
have tried a early jeep knuckle but isnt as beefy, kingpin bolts are a diferrant size, there is an additional 4mm slop on the inside of the knuckle, ie up&down, tie-rod hole is smaller and it is 4mm shorter in depth which reduces turning circle and rubs on the shocky....
Daily Driver
