disc brake swap
jimmy828
disc brake swap
Post by jimmy828 »
i am making plans to swap the front drum brakes to disc brakes in my 1969 f100.I want to do this myself.If anyone has tips on this project please fill me in.I just purchased this truck and want to start with the brakes first.THANKS
Re: disc brake swap
drop the donor axle and radius arms all in one piece. remove the nut fromt he radius arm remove the axle pivot nut and botl then remove the upper sprign clamp and shock. as well as the brake line. it will all drop right out very easily.
jimmy828
Re: disc brake swap
Post by jimmy828 »
i have shopping around for new swap parts for brake system.Any tips
Re: disc brake swap
get them from a 73-79 truck. dont forget to get the brake valve while your getting the parts.
seattle67
Re: disc brake swap
Post by seattle67 »
Dan
bigmerc2003
Re: disc brake swap
Post by bigmerc2003 »
Where are you located? I have a 77 f150 frame with a complete and good front disc brake set up, make an offer for the whole thing and you shopping is done!
19FORD67
Re: disc brake swap
Post by 19FORD67 »
might as well go to power steering if you don't have it while you got it all apart. You can get most of the parts from the donor truck as well.
:fr:
'92 Mercury Cougar
thorn1968
Re: disc brake swap
Post by thorn1968 »
I'm finally getting around to troubleshooting and fixing an incomplete disk install done by a shop that the PO used. Make sure you get the disk proportioning valve off the donor truck. Get the master cylinder as well, the drum brake master won't work. If your truck doesn't have power brakes, get the booster and bracket off the firewall. The booster might now do you any good, it will probably have a different rod assembly, but you can use it as a core. :2cents:
Re: disc brake swap
the drum master will work if you remove the residual vavle inside of the master feed line on the rear compartment. as long as the rear master is a larger than the front it will work that way.
thorn1968
Re: disc brake swap
Post by thorn1968 »
fordman wrote:the drum master will work if you remove the residual vavle inside of the master feed line on the rear compartment. as long as the rear master is a larger than the front it will work that way.
I never figured out how that worked...I'm sure that's been my problem since I got my truck. :doh:
Re: disc brake swap
ive only read about it. and i know i have seen a diagram on them on the site. you may want to search for residual valve and look fo rone of kieth's (fordification's) posts.
19FORD67
Re: disc brake swap
Post by 19FORD67 »
You can remove the residual valve on the disc brake side and leave the one on the drum side.
If one side is larger this should be the one for the front disc.
There's a pic under one of my post titled "master cylinder".
:fr:
'92 Mercury Cougar
