Steering me in the right direction
Fordman5
Post by Fordman5 »
I need some advice from all you. I am looking to change out my steering column with a tilt wheel as for forth. I want to find one that takes limited custom work, and does not cost an arm and leg. Pics would be helpfull as well if you have them. Thanks all. Oh yea I have a 67 bump manual steering, but I am not going to to power steering though, to much to go wrong for a simple guy like me. Any ideas will be helpful to me, thank you all :fr:
Proud owner of a 1967 Ford F100
Racer Z
Re: Steering me in the right direction
Post by Racer Z »
Racer Z wrote:Never done it, read this:
http://www.fordification.com/tech/tilt.htm
thats the easiest way to go. is with the 73-79 columns.
Fordman5
Post by Fordman5 »
Yea but a 3 on the tree is what I need as well. I will check into it.
other than that link to hotrodders or whatever its called. they never made a 3 speed tilt column. i dont know that it could be done either.
Hawkrod
Post by Hawkrod »
Running a tilt on a manual steering truck is a disaster waiting to happen which is why Ford never offered it as an option on the big vehicles. Tilt components are actually pretty fragile and they break even on PS vehicles that have significantly lower steering loads. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
