I've got a couple of stripped rear wheel studs. LMC and Dennis C only show front studs available. The local auto supply replacements are way different.
? Is there truly a difference between the front and rear studs? I figured the fronts from LMC have to work on the rear.
I guess I can always go to the salvage yard and pull a few if necessary.
Wheel Studs
Wheel Studs
71 F100 302/3.03 Project Truck Underway
- customcrewcab
re: Wheel Studs
go to napa bring a lug nut with you. is it a 9" or a dana 60? you can get longer stronger one at http://store.summitracing.com/default.a ... search.asp
maybe you can see which one you need in the pics on the link
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
