I have been trying to find a schematic of grease zerk locations for my 1971 f250 c.s. 2wd.
I have had no luck and am requesting info. I wanna make sure I don't miss any zerks. Not sure if this is the right place to post this, but it seemed that most of my zerks are steering related save for drivetrain... any help is appreciated.
zerk locations?
- cozadlance
- 390Nut
Re: zerk locations?
If it is a 2WD, you'll have two on each spindle, one on top and one on bottom. Also one on each end of the steering linkage, where the linkage meets the spindles, one where the two pieces of the steering linkage meet, and one where the steering linkage meets the pitman arm on the steering geerbox. Aside from that, the rest are on the driveline.
Paul
`69 F100 390 4spd driver
- cozadlance
Re: zerk locations?
thx. then I have found them all. Now I need only buy an ez-out for the broken one.
update when I can afford it and a new oversize.
