I fliped the hanger
- sport71
I fliped the hanger
I fliped the hanger to lower the rear and of course the pinion is off. I put a 6* shim which is a bit to much. So I took it to my local 4x4 shop and the guy there confermed it. He also said that since I droped the front hanger that I should do the same in the back. I thought that the pinion angle could be fixed just by shims alone, or do you think that this guy just wants to make money off of me by adding hangers and more labor= $375? (the shims $20 at home)?
Those who do not learn the lessons of history, are doomed to repeat it.
Re: I fliped the hanger
No, you don't need to drop the rear hangers to match. You simply need the correct shim.
http://www.summitracing.com/search/Part ... gle-Shims/
Like keith said all you need is a shim. I flipped the rear hanger on my highboy to lift it and it had a BAD pinion problem went to the 4x4 shop I think I used 6* but it seems to be ok now.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- sport71
That's what I figured, just that I couldn't get the guy to tell me otherwise. I just orderd two sets of 2.5* and one set of 4*FORDification wrote:No, you don't need to drop the rear hangers to match. You simply need the correct shim.
I know that it will work with just shimming it, and every little thing that I'm doing for final adjustments are sure making my truck better.
- sport71
I'm glad that every thing turned out good for you. It seems to me that everyone down here just wants to take my money.FordTruck wrote:Like keith said all you need is a shim. I flipped the rear hanger on my highboy to lift it and it had a BAD pinion problem went to the 4x4 shop I think I used 6* but it seems to be ok now.
Oh they were trying to get me to bring it to them but I wasn't about to do that becuase I had a good idea what they where gonna try and do and how much they where gonna try and get me to paysport71 wrote:I'm glad that every thing turned out good for you. It seems to me that everyone down here just wants to take my money.FordTruck wrote:Like keith said all you need is a shim. I flipped the rear hanger on my highboy to lift it and it had a BAD pinion problem went to the 4x4 shop I think I used 6* but it seems to be ok now.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
How did you know the angle was wrong? Just asking to learn. thanks.
"I'm not saying, I'm just saying"
1972 Ford F250 C/S XLT 390 NP435, purchased from the son of the original owner, now named Yoda
1967 Ford f100, currently. (2nd Titled owner) Now named Captian Hook
- sport71
It vibrates when you accelerate.onetuford wrote:How did you know the angle was wrong? Just asking to learn. thanks.
I'll post how it comes out once I put the correct angle shims.
Hey sport71,
Each truck is different but I did the half hanger flip and I had to use 6 degrees shims.
Kind of a trial and error thing.
Good luck and get us a couple pics. when you're done.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
- BobbyFord
The difference is that not everyone has the same weight rating springs in the rear and some springs are arc'd more or sagged more than others, thus the need for different degree shims to bring the pinion angle back within specification. Plus not everyone bolts the front shackle back on the frame in exactly the same spot. The easiest way to determine what shim you need is measure the pinion angle before after the shackle flip and then subtract the before number from the after number.Calvin Gunter wrote:Hey sport71,
How do you measure the angle?
- BobbyFord
Angle finder, available at your local home improvement center or Summit racing.onetuford wrote:How do you measure the angle?
- sport71
You all are not going to beleve how much angle I needed. I needed 8.5* I couldn't beleve it. But that's what it needed, and now it's smooth running with no vibration. I am going to put the correct lowering hangers on it because on the rear shackle I have no flex for a softer ride. I rely don't know yet though.
- BobbyFord
sport71 wrote:You all are not going to beleve how much angle I needed. I needed 8.5* I couldn't beleve it. But that's what it needed, and now it's smooth running with no vibration. I am going to put the correct lowering hangers on it because on the rear shackle I have no flex for a softer ride. I rely don't know yet though.
- belair53
I'm in the process of flipping my front hangers also. I started out just going to change my center support for the drive shaft and the next thing I know I was cutting the heads off the factory rivets. I'm having a hard time drilling out the center of the rivets but I'm getting there. Wish I had taking pics before I started. Going to post pics when I'm finish.
For with God all things are possible. Mark 10:27
53 Chevy Belair, 68 Ford F100, 86 Mercury Grand Marquis, 93 Ford Splash, 96 Mazda 626, 06 Nissan Altima. All My Rides.
