I have an opportunity to buy a rolling chassis from a 71 F100 2wd, 9" rear for $100.00 ...I want to convert my 69 F250 to 5 lug and be able to use dream beams.
Although the F100 is drum brakes and my F250 has disk brakes, can I bolt up disk rotors to the new spindles off the F100 so I can keep the front disk's?
F250 to F100 front brake question.
69 CrewCab Shortbed
84 Bronco built for the desert
Life is 99% what you make of it....So if your life sucks....You suck...
- 69rangerf100
Re: F250 to F100 front brake question.
the spindles on the F100 are completely different from the F250 spindles
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
I meant F100 disks to the spindles that are drum off the F100.
69 CrewCab Shortbed
- 69rangerf100
i will take some picks of the drum and disk F100 spindles tomorrow and post them for you
David
you will need the calipers and disc brake stuff from a dentside in order to sawp to a 5 lug disc setup.
Ok...so I can bolt up the disk brake stuff to the spindles that now have drum brake on them....please excuse my ignorance, just trying to make sure I can accomplish what I want to do.
69 CrewCab Shortbed
i think repeat i think yo ucan just remove your rotor and brake caliper holder from your current F250 spindles and put the rotor and brake caliper brackets on from a dentside. no need to use the drum brake spindles or any of that from the drum brake setup.
