Gear box
maverickfe390
Gear box
Post by maverickfe390 »
Anyone know how close there is too anything by a gear box in a 1967 F-100 4X4 manual steering? I found a power steering gear box from a bronco that goes on the outside where the not PS goes. ( I have my F-100 all torn down as of right now so I cant see if the gear box will have the room from the box too the core support )
Doug Comer
Re: Gear box
Post by Doug Comer »
From what I know :hmm: I think the bronco boxes bolt right in but are pricey. If you have one your already ahead. :thup:
Doug
1967 f100 4x4
1970 f250 4x4
maverickfe390
Re: Gear box
Doug so your saying it would work because I know the holes dont line up I would have too redo that.
maverickfe390
Re: Gear box
Can any take a picture of how much room there is where the gear box is at a 1967 4x4 who has one? just like how much is there from gear box too core support?
Doug Comer
Re: Gear box
Can you post a picture of the box?
1967 f100 4x4
1970 f250 4x4
maverickfe
Re: Gear box
Post by maverickfe »
Doug here are the pictures that you asked for. The top of the gear box says C6AR3580-A the 6 might be an 8 cant tell. I know it was from a full size Bronco. The other tag says SPA-BT 8A 17.
1966 Galaxie Convertable
1967 F-100 4X4 390
1967 Cougar XR7
Doug Comer
Re: Gear box
I think :hmm: one hole lines up. The lower left one. Then drill the other two. If I recall correct, this is the same box thats on my 67.
Doug
1967 f100 4x4
1970 f250 4x4
maverickfe390
Re: Gear box
Thats what I thought too just by looking at it. But how did you put nuts on the other two? They look like they would be behind the cross brace? I cant remenber if the pitman arm needs to be turned around or not either? And what about the shaft did you switch too a differnt column? Are the holes that you drilled too put the the gearbox in are they close too the other holes?And it was ok by the rad support?
Sorry about all the ? Just like too try and get this some what done befor winter hits up here and like too put some paint on it too. Can you put some pictuers of it?
Doug Comer
Re: Gear box
I will tyr to answer these one at a time :lol: . I think there is acsess holes on the front of the crossmember on the inside of the frame. On mine the pitman arm points forward, if it pointed back when you steered right it would turn left. There is a solution to that but its a whole other story. I left the steering column alone and cut the old shaft, shortened it, and welded it back together. I don't know how close the holes where to the others, and I don't recall cutting the radiator support. I did have to cut the inner fender a bit. I can try to post pics but it might take a couple days, kinda busy lately.
Doug
1967 f100 4x4
1970 f250 4x4
maverickfe
Re: Gear box
Thanks for the replay Doug. The two back bolt hole that I will have too drill out new ones will be inside that cross brace that goes too the other side if i use the front hole.Think i will have too cut a hole in it too put nuts back there and weld up.On mine with no ps the the pitman arm points back,the one I got off of the bronco i think was going too the front.
1967 F-100 4X4 390
1967 Cougar XR7
Doug Comer
Re: Gear box
All the photos are click to enlarge. First pic shows the distance from the box to the radiator support and inner fender trimming. Second and third show the back two bolts going thru the boxed section and the acsess hole in the bottom of the crossmember. Fourth is the acsess hole. Fifth is the shortened shaft. The last shows the box positioned on the frame with the arm pointiong forward. Hope this helps. :thup:
Doug
1967 f100 4x4
1970 f250 4x4
maverickfe390
Re: Gear box
doug thanks for the pictures I will get you some after I put it on friday.
maverickfe390
Re: Gear box
Doug did you get a differnt Drag link because my link is one piece the tierod ends do not adjust at all one soild piece? And all I can get is one end of it the other will not slide in. If you did do you know the part number and what part store you got it from?
Doug Comer
Re: Gear box
Yes. I had to make it.
1967 f100 4x4
1970 f250 4x4
maverickfe390
Re: Gear box
May I ask what did you use? Yea because the push's that draglink way out .Was there any more mods you had too do is there any trouble with the turning now?
