Steering box nut
Will
Steering box nut
Post by Will »
I went to put the nut from my manual steering box onto my saginaw power steering box and it does not fit anybody know what size nut this box would take.Thanks
Re: Steering box nut
which nut? the onethat holds the pitman arm onto the main shaft?
fordamericana
Post by fordamericana »
Or the one for the adjustment screw? Got pics of what you are talking about?
I likes My FE I does...
Will
Post by Will »
Yes the one that holds on the pitman arm sorry about that.Will
67F10YR
Post by 67F10YR »
I'm swapping my manual steering in my '67 for power steering from a '72. I don't know the size off the top of my head, but I can check for you when I get home tonight and let you know tomorrow.
Will
Post by Will »
It turns out they are the same size as one another my saginaw had sone screwed up threads at the begining fixed that and the nut went right on.Thanks for the replies Will
