1967 ford f100 newb sensitive steering
i recently purchased a 1967 ford f100 shortbed the truck is in pretty good condition mechanically wise i need help with the steering i changed the shocks and all new tie rods whenever i go through a rough road my truck loses control and wants to get off the road also the steering is way too sensitive it is hard to drive becouse any slight movement the steering wheel it swerves all over the road please help me out as im running out of ideas i was thinking it could be the rag joint gearbox or power steering pump the truck does have some camber issues i really like my truck and dont want to get rid of it over this issue i will be posting some pics as soon as i can
Re: 1967 ford f100 newb sensitive steering
a bump or uneven road will cause any vehicle with camber issues to pull towards the wheel that goes over the surface. Why does it have camber issues did you lower it ?
- one_am
sounds like your toe is off. if your wheels are toed in it will look like the wheel is cambered out as well due to force being applied inward on the bottom of the tires. (positive camber). i had a Saturn do this to me. It was like the car was tiptoeing across the road and the tires stuck out at the top. if you let go of the wheel it would start whipping back and forth violently! Did you have the truck aligned after you replaced the tie rods? If so i would have it done again some where else
69 F100 custom cab swb 460 c6 9 code rear axle (project).
bjde0b wrote:I jacked a sway bar off...
no i recently purchased the truck i once had a dentside with no issues like this but it is not lowered to my knowledge and i did have my truck aligned once i installed the tie rods but not at any tire kingdom just a local shop what i dont like is that the steering is too sensitive
It's the alignment. Just take it to a different shop and have them check it out.
- one_am
thanks for the help ill make sure to get that done this weekend and hopefully get her on the road soon
my impression is that everything is in good working order and you arent use to driving a truck with such good steering. but i could be wrong. have that other shop check the whole steering system out. they will either find it or tell you to drive it like a new truck.
i got the truck alligned and my pitman arm was off now it drives like a dream the only downside is that when i hit a turn the steering wheel wont go back to its original position im thinking its the gearbox or ps pump
sounds like they got the pitman arm put back wrong. they only turn so far each way before bottoming out.
- LUB69F100
Not enough positive caster.
so sayeth about.com
Lub
so sayeth about.com
Lub
Remember, when someone annoys you, it takes 42 muscles in your face to frown. BUT it only takes 4 muscles to extend your arm and smack the idiot upside the head.
I child-proofed my house.....but they STILL get in!
