4wd front disc
4wd front disc
here are some bad pictures of a dodge ram disc brake set up. will these fit and work on my D44 open knuckle? it is easy to get at . but i havent even looked at my axle pictures to see if it is even close.
averagef250
Re: 4wd front disc
Post by averagef250 »
Sure, those knuckles will bolt right up to any balljoint 44, but then you have the eeny weeny dodge 1/2 ton lug pattern in front.
Re: 4wd front disc
i think its the same bolt pattern i have now. unless that is the smaller dodge bolt pattern and then i wouldnt do it. because i dont want two spares. i will check before i pull them.
Doug Comer
Re: 4wd front disc
Post by Doug Comer »
Looks right to me. The ones with the small bolt pattern didn't have locking hubs, I think.
Doug
1967 f100 4x4
1970 f250 4x4
Doug F
Re: 4wd front disc
Post by Doug F »
Why not just look up and get a newer Ford D44? I got a 76 or 77 I don't remember now... All Ford parts and easier to find replacement parts since it is a newer vehicle/axle.
http://www.mypartshop.com
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
Re: 4wd front disc
here is another picture of the drivers side hub it is a dana 44-8-f. the axle pumpkin sits to the passenger side instead of the drivers side.
Doug F
Re: 4wd front disc
Post by Doug F »
They list all the way down to Hubs and Knuckles and Spindles even!
Here you go, this is local to me:
77
F150 Spindle Knuckle, Fr
LEFT CHECK ON
Stock # D77147 Part # 1512
77
RIGHT CHK ON
Stock # D77147 Part #1511
BOOT HILL AUTO PARTS ask for Tony, he knows his scheisse!
303-294-0466
800-762-7042
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
Re: 4wd front disc
i did not even bother looking. i have used the search before. and it does turn up parts. parts that are way more expensive than i can pay for these. because o fmy finacial situation why would i go out and pay three or four times what i can pay for these?
bigmerc2003
Re: 4wd front disc
Post by bigmerc2003 »
I have a set of 3/4 ton 8 lug axles from a highboy I bought a few years back. The Front is a Dana 44 with the big hubs and the rear is a dana 60 (I also have a Dana 70 DRW axle). I am in IL about 60 miles south of Chicago so its a drive but let me know if its something that could help you?? I need them gone because I dont have my project truck anymore and lost my storage spot for them. They are complete with lift blocks and springs, just need to be cleaned up from sitting.
