Doing front disk upgrade, question about trailing arms
kraftor80
Post by kraftor80 »
Hello,
I am swapping front I-beam, disks and steering (including pitman arm) from a 76 F250 into my 70 F250. My question is the trailing arms look different. The 70 is cast and the 76 is pressed? Otherwise they seem the same. Can I swap them too? I see no mention of trailing arms in the tech data on disk break swap.
69rangerf100
Re: Doing front disk upgrade, question about trailing arms
Post by 69rangerf100 »
the radius arms you can either use the stock 70 or switch to the 76 arms doesnt matter they are the same length. i lucked out and got a donor 73 disk setup so i am able to keep my i beams and just put the 73 spindles on since the kingpin size is the same
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
You can use the '73-'79 radius arms on your bumpside, but if you do, you also have to use the matching front springs. The dentside springs use a different spring cup that won't sit right on the early forged-steel radius arm. You'll be fine as long as you keep use the springs and radius arms as a package, don't mix.
kraftor80
Post by kraftor80 »
Thanks very much! I was going to keep the 70 springs as they have more turns so I suspect they will be a bit better riding.
Image*Image
The 70 spring ......................The 76 spring
Both seem to have the same length, but the 76 springs have these blocks wedged in. I am guessing this is a method of raising the front a bit either springs compressed over time, or someone wanted it a bit higher.
The spring block.
69rangerf100
yeah my front end had those on it i think my dad had put them in at one point since they were factory springs on it
David
i thought you could use what ever springs you wanted as long as the cups matched the springs. wont the cups fit on either style or radius arm?
