Leaf spring bushings?
- JWW
Are all six leaf spring bushings the same size?
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
- Caseys71
Re: Leaf spring bushings?
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
On the rear springs I believe the front bushings are bigger than the rear four.
- Caseys71
cep62 wrote:On the rear springs I believe the front bushings are bigger than the rear four.
Casey
the flex o matics used two one size and two a different size. http://www.lmctruck.com/icatalog/fb/t.aspx?Page=104
the non flex o's used 3 all one size.
http://www.lmctruck.com/icatalog/fb/t.aspx?Page=108
- JWW
OK, so LMC is saying the non flex o matic spring bushings are the same. They have two different descricptions:fordman wrote:the flex o matics used two one size and two a different size. http://www.lmctruck.com/icatalog/fb/t.aspx?Page=104
Spring Eye Bushing (4 required)
Shackle Bushing (2 required)
Thanks for the links Fordman.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
The standard springs are the same bushing, I just did mine earlier this year with Energy Suspension's poly bushings. Wasn't easy, but sure made a difference.
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
08 VW R32
