remove the front spring bracket. flip it upside down and put it back on. but once you do that yo upinion angle will be wrogn and it will wear on the rear end parts and or u joints.
same possible problem. you can reset the pinion angle by using shims once you do the bracket flip. the shims go between the spring perches and the springs.
