Body Mount Question
Body Mount Question
Does anybody know if the front body mounts are available from any vendors? I've been looking, but can't find them. Mine are pretty rusted out on the end and I'd like to replace them. I'm trying to post a pic of the area, but I'm having trouble. Also, one of my front coils is messed up. If I head to a junk yard, are there any coils from any other trucks that will work?
Re: Body Mount Question
have you looked at lmc truck in lenexa? they sell bronco and truck parts.
edit 66-77 bronco part numer 40-0127 rubber.
polyurethane part number45-1500.
ford truck part number core support rubber 43-0960
cab rubber 40-126
cab rubber 40-126
- BobbyFord
Cab mounts?
- BobbyFord
Cab mounts?
Wish I could get the pic to load. I called it the wrong thing. I'm talking about the metal ears that stick out of the frame that the cab (and mounts) bolt to.
no you have to buy those from someone who will take them off a frame for you. or you can repair them by welding in a washer several guys have done that too. hang on i will go find where they did that at with pictures.
here you go it was flyboy 71 that showed the pictures of how it was done on this page. http://www.fordification.com/forum/view ... in#p435026
Great. Thanks. I hadn't thought about a washer or somthing like that. My father-in-law is a pretty good welder, I bet he could do it. I welded a little in high school, but that was in 1984! I'd like to get a welder, but I think I'd start out on something a little less important. Thanks again.
Brian
Brian
