Spewing power steering pump
f1shermun
Post by f1shermun »
I have a 72 f-250. I havent had any issues with the power steering until recently. If I am at a dead stop and cut the wheels from left to right the pump will spew fluid. It will only do it at an idle.Is this normal?
Re: Spewing power steering pump
no it isnt normal.
f1shermun
Post by f1shermun »
Do you have any idea what might cause it?
70_F100
Post by 70_F100 »
Mine will do that with the engine stopped, but at an idle, it does fine.
Does the steering work okay above an idle, or have you noticed either a slight or noticeable change?
look at picture number 7 and read below it under diagnosing power steering complaint. it is a stuck relief in the pump. http://www.fordification.com/tech/PDF/F ... gnosis.pdf
f1shermun
Post by f1shermun »
okay, i bought a new pump from autozone and a new pressure line. I dont seem to have any leaks but I have new issues. The pump has a steady whine and It doesnt seem to have the pressure to turn my wheels to the right. I thought it was air in the system. I lifted the wheels off of the ground and turned the wheels back and forth until I almost had a blister and It is still hard to the right. I am beginning to think that the pump is junk. Any ideas?
the ford pumps origninaly used type F transmission fluid in them not power steering fluid. that may be why it whines.
f1shermun
Post by f1shermun »
Do you think I should drain all of the type F out and fill it with power steering fluid? Any ideas on why it would be hard to steer to the right?
70_F100
Post by 70_F100 »
AutoChina pump... :doh:
no it should have tpe f fluid in it. not power steering fluid. if that isnt the problem i think there is a tsb about the pump whine. it might be under the pump rebuild page it is called power steering noise complaint.
f1shermun
Post by f1shermun »
There was a pin hole in the pressure line that was sucking air into the system. I replaced the line and followed the steps listed in the above posts. The remaining air eventually worked its way out. I now have good steering but the new ATCO pump i have is still whining. Autozone offered to replace the pump. With all of the trouble and money to get the air out of this one I am hesitant to pursue the free replacement.
