disc conversion,
Heathcliff68f100
disc conversion,
Post by Heathcliff68f100 »
Ok, i have a 68 f100, and basically im thinking of converting to disc brakes. i read this
http://www.fordification.com/tech/Ibeamsspindles.htm
But it kinda confused me, is this saying i can swap the beams and spindles from a 74-79 ford f100 and be done with it, just drop and swap, i dont have to keep my beams, remove kingpins, and swap the spindles? i appologise for my confusion in advanced, but would appreciate someone to clear this issue up for me
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
Re: disc conversion,
this quote from above the kingpin size chart says it all. the i beam king pin sizes have to match the spindles and the i beams you plan to use.
"If you're using '75-'79 spindles, use '75-'79 I-beams and kingpins
If you're using '68-'74 spindles, use '68-'74 I-beams and kingpins
If you're using '67 I-beams, use '73-'74 spindles and kingpins. However, the round pin used for the bump stop in the '67 I-beam may need to be trimmed or modified, as needed. "
Heathcliff68f100
so basically, if i can find a 74 f100 with disc brakes, just drop and swap, and im good to go, beams, spindles and all, ?
thats what it says up to and including 74.
basketcase0302
Post by basketcase0302 »
Wasn't this all the way through 79'?
Our member Uboughtwhat got the beams and spindles from my 79' a few years back, don't know if he ever got the conversion done though? :hmm:
70_F100
Post by 70_F100 »
As long as you get the I-beams, spindles and all of the other parts, you're correct, it's just a "drop-and-swap" conversion.
The only time the year model comes into play is when you want to re-use your original I-beams.
:yt: exactly
