Backup Light Switch Lever?
- sargentrs
What is this? '71 Ranger, P/S, automatic. Sticking up out of the lower end of the steering column. Looks like it's broken off? Is this, maybe, the lever arm to operate the backup light switch? Is it replaceable or welded on? Anybody got one? Thanks!
- 70_F100
Re: Backup Light Switch Lever?
That's the lever that operates the neutral safety switch for an auto tranny. It looks fine to me.
Your sig shows a "3-on-the-tree" tranny, so I can't understand why you would have that on your column.
The manual transmission backup light switch is located under the hood, and is operated by the lever that connects to the 1st/reverse lever on the tranny.
That's not an oil leak
That's SWEAT from all that HORSEPOWER!!
- sargentrs
Sorry, just starting on a swap and haven't changed the sig yet. Guess you could say I'm ridin' the fence for a little longer70_F100 wrote: Your sig shows a "3-on-the-tree" tranny, so I can't understand why you would have that on your column.
Ok, then, I guess I better get under there and look for what that was supposed to be contacting then. Thanks!
the nss/ back up light switch is missing from that column. but the lever is fine. it snaps into the column.
- sargentrs
Bolts directly to the column, right? I saw it in vendors catalogs. Expensive little booger ain't it. Saw one on ebay for $25 though. That one goes on the To-Do list for install. Thanks!
