YAfter seein an article in car craft magazine I want to check out praise dyno brake shoes.
http://www.praisedynobrake.com/
along with a smaller mc maybe from wilwood but what size?
http://www.carcraft.com/techarticles/cc ... index.html
What y'all thing about that? For better drum brakin?
drum brake setup
Re: drum brake setup
master bore size should be the same size as the wheel cylinders or calipers you are using now. if your master is a 1 1/8 bore you want to stay with that. unless you are upgrading to disc brakes then you want the same sized bore master as the disc brake truck used.
But they were sayin smaller nore increases pressure rite with less pedal travel ?
- knightfire83
It would result in more pedal travel to fill larger wheel cylinders with a stock master cylinder. But less required braking effort at the pedal due to a larger pistons in the wheel cylinders.
1970 Ford F250 4x4 ~ Sold.
