front bumper brackets
- 1971ford
So you have to have some sort of brackets to mount a stock chrome front bumper to a 4x4? What do they look like? pics?
-Ryan
- CO684X4
Re: front bumper brackets
I don't think you do. Mine just bolts to the frame horns on my 68 4x4 F100
- averagef250
F100 4x4's are pretty close to a 2wd. The 250 4x4's use special brackets just like the F-350 and larger 2wd trucks do. The F-250 4x4 bumper brackets are the same from 67-77.5 and are on most F-350 2wd and larger trucks too if they had the pickup style front bumper.
yes the F250 4wd and F350 2wd use these brackets. here is a ended auction for a single side. http://cgi.ebay.com/ebaymotors/ws/eBayI ... K:MEWAX:IT
- 1971ford
oh ok cool. yeah it's a highboy.
Thanks I'll be looking for them at the junkyard.
-Ryan
Something I always thought about doing if a guy couldn't find them. Use the front section of a two wheel drive frame (which are easy to find) cut it off and make a set. I never tried it but why wouldn't it work?
Doug
![Don't know :dk:](./images/smilies/icon_dontknow.gif)
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
i looked at doing that. and on the 2wd frame where that angled slot is . it is raised in that area on the one i looked at. so it made it too short tocut off and use to have enough there to make the attachment. but you could cut off more of the frame and try and bolt them on anyway.
- 1971ford
will bumper brackets off a dent work with my bumpside front bumper?
nevermind. Dustin already explained this earlier. Thanks
-Ryan
there is a guy on ebay who sells these if you want his name.
- zakt
Ryan I might have some I don't need. Let me look when I get home on Sunday and I will let you know.
- zakt
mljjones67 - Im looking now at the picture of mine and the ebay link above, I notice the top of mine are angled in. Are those suppose to be straight across?
1972 Ford F350 crewcab
![Image](http://www.fordification.com/galleries/albums/userpics/10045/350emblem~1.jpg)
They will probably straighten out when the bumper bolts are tightened.
Might have had a bent bumper on there before
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
I will get some pics of mine up if in fact that's what i have at home. I will be back home on Sunday evening. I do think that mine look a little different though.
- mlheppl
Don't know if this helps or not, but here's my brackets still bolted onto my bumper
![Image](http://img.photobucket.com/albums/v630/mlheppl/Ford%20truck/Bumperbrackets.jpg?t=1269557556)
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
